Early Boats with Mast Step Failure ??
24 Jul 2020 07:37 - 24 Jul 2020 13:43 #1 by Take Five
Chris Z wrote "Keep in mind that the early boats had mast step failure and needs to be reinforced from the inside which requires the installation of an access port."
My Force 5 boat is from 1974.Is there something that I should do, to avoid a failure?
I had no problem until now, but probably the boat was not used very hard until now. I bought it last year.
Best Greetings from Germany
Peter
Last edit: 24 Jul 2020 13:43 by Take Five.
25 Jul 2020 08:28 #2 by JeffNH
While we wait for experienced boat mechanics to chime in, I'll just mention that the boat I recently bought is a 1986 model. The previous owner did do a mast step reinforcement on this boat, as well as work around inside the transom area. So there are 2 inspection ports, one in each location.
27 Jul 2020 14:10 #3 by Chris Z
21 Mar 2021 17:43 #4 by Take Five
Hello Chris
The link does not work any more. How can I get information about this problem. You wrote to others who are new, that it is easy to fix. My Force 5 is from 1974. So I think I should check this.
Thanks a lot
Peter
Time to create page: 0.697 seconds
Powered by Kunena Forum
